- Jan 25, 2015
- 2,558
I refurb a fair bit of old equipment and do reasonably well with it.. It's mostly a budgetary thing more than a hobby thing. A lot of metal working machines are too expensive for me new, so I usually buy "unloved" stuff and rebuild it. Latest is a 5" B&S mill vice.
I find myself having a need for a small surface grinder more and more. I'll never need to grind anything much longer than 6-8" at the most.
Used isn't an option around here, they just don't exist. Heck, it's hard to even find a used lathe here, Chinese import or otherwise and if you do happen to find something, people want a stupid amount of money for clapped out machines. Or the other thing that may show up used is HUGE industrial sized machines, which are simply not an option for me, both in cost, mains power, moving it and available shop space.
New? Well...see above mentioned "budgetary" concerns. Just not an option and my price point (assuming I can even find one I can afford) would be so low the machine would likely be junk anyways.
So I'm thinking I might give making one a try. Looking at the image below, I just about have all of it. So financially it's not a big burden. Space isn't a big concern as I can make it as big or small as I want for the space I have available (which is to say not much space available).
Some googling turned up this image (among others):
Looks to be home built. I have a cast iron xy tslot table gathering dust and the upright on that one looks speciously
close to the Atlas Milling attachment hanging on my pegboard (have a mill , no longer need the attachment). Motors, pulleys, etc I've got hanging around.
I know it will never be as accurate or as rigid as a purpose built unit, but given the choice of a diy surface grinder or none at all, it worth giving it a try?
For the milling attachment, I'd be using it without modifying it. I'll just build a plinth that the atlas piece will attach to like it does on the Atlas cross slide.
Mag chuck isn't in the cards in the near future either. I've seen a couple DIY permanent magnet one (rare earth) and that might be an option down the road.
If you feel it's not worthwhile or are "agast" at the thought of it, please be kind with your responses and try to be constructive with your criticisms.
