- Oct 11, 2016
- 3,864
On the start up equipment, you have enough to get started and do a lot of different things. You will also need a block to hold the diamond at a 5 degree angle... Contact me if you want me to make a drawing for you. I have an old soft one and am currently making a tool steel, hardened replacement to be my permanent diamond dressing block.
Please don't mill the chuck!!! The alternating layers in the chuck are soft then hard - it takes some special work to do it well, which will probably be unnecessary.
Instead, take most of the bad surface rust off with a 3M pad and varsol or wd 40 or whatever your petroleum lube of choice is. This will tell you about the reall extent of the damage. Remember a hole doesn't hurt you, but a volcano is a disaster. You will be grinding the chuck in anyway, so just clean it up so you can inspect it. If you have more than 90% contact left, then just grind the chuck true and go for it! In subsequent resurfaces, the holes will slowly disappear (!!)
It sounds like your are going great guns!
