Surface Grinder for a hobbyist
Got my table back together with the repaired shaft and new bushings. I cleaned the oil ports and made sure the port going to the table handle was lined up.
Then a made a locking nut for the arbor since I have right hand threads on it and it's come loose a few times in my 'testing'.
It's made from 3/8 hit rolled plate with a cold rolled pin for the lock. I was nearly done when the magic smoke came from my milling machine.. guess I'm calling PM today, so ground the flats in it to engage the groove in the arbor.
Found this Sanford 6x12 just 15min from my house a couple of weeks ago and scooped it up. I think its an MG but it doesn't specify the model on the column like projectnut's a few posts above.
Like most of your finds: this one was dirty and had quite a bit of crud and plugged oil galleries. I wanted to do a full strip and refinish, but for now I just thoroughly cleaned it, blew out the ports (shot 1" slugs out of a couple), and cleaned/stoned the ways. Everything is really smooth and motor is decent - only problem is the extremely worn cross-feed nut & leadscrew: but that's fixable.
I have yet to find a picture of one which has the full wrap-around guard. Someone hacked in a crooked opening in the guard so they could more easily operate the chuck. I milled it square so its a bit more presentable. :) Should be a good addition to the shop.
That nut is about as worn as worn gets!
You're not kidding! Only about half the thread is intact and crest is sharp as a razor (originally is a 0.750" 5TPI square thread). Will probably redo in acme.
Yes, do it in acme, it is a good deal easier to machine both the screw and nut. And it is stronger and has more wearing surface area.
It's a slippery slope. I thought all I needed was a lathe and a mill. And a cut-off bandsaw. And a bench grinder. And a TIG welder......
You get the picture. If I could find a surface grinder for $300, I'd get my wallet out before they change their mind.
And yes, you'll need a mag chuck.
I have one I'll sell you for 400 with a mag chuck.
Your right about the guard being modified. Attached is a sales brochure from 1965. Note the low section of the guard is only a few inches lower than the ends. It may have been modified to accommodate a different style chuck. The chuck on my MG has the factory "Sanford" label on the front and the on/off lever on the right end. The chuck has the on/off lever on the front where it may have been difficult to access with the higher guard.
  • 1965 Sanford MG Sales Brochure.pdf
