- Mar 26, 2018
- 8,409
Hi,
Can someone direct me to an easy to understand way of determining the best surface grinding wheels?
I went into Norton's web site to find I needed to choose between the following;
Wheel type,
Diameter,
Thickness,
Arbor size,
Surface Texture,
Grit,
Abrasive Material,
Norton Style,
Abrasive grade,
Bond,
Once you choose a category, there are sub-sections within each.
The first few are easy but when it gets into the details I get lost.
Thanks for the help.
Just trying to get educated.
Wheel type,
Diameter,
Thickness,
Arbor size,
Surface Texture,
Grit,
Abrasive Material,
Norton Style,
Abrasive grade,
Bond,
