- Nov 28, 2010
- 26
Anyone have any thoughts on how to go about making a couple of piston rings? I acquired an old moped bike with a locked up motor, and in getting it freed up the rings broke into many parts. The piston is 40.2 mm dia and the groves are 1.5 mm wide by 1.8 mm deep. I don't have a surface grinder, but am thinking if I could find some the correct dia I could sand them thinner if needed. An online search has so far not turned up anything other than some China mfgr wanting to sell me several thousand. Material is another question. The original ones were cast iron, I think, would steel work? Perhaps a piece of cast iron pipe could furnish the stock, if I can find the right dia. Pipe with 1.5 ID and .125 wall should do fine. What actual dia should they be turned to? Will they spring open when the gap is cut? Any thoughts are most welcome, Thanks, John
