As a rule, I tend toward Precision Twist Drill (PTD) when I can get them. Over many, many long years, I have accumulated full sets of Fractional by 64ths, Number, Letter, and Metric. Also a set of fractional by 32nds Left Hand drills. The Left Hand drills were a HF index. Not that good, but I needed one drill and ordered a set, cheap. Left hand drills are not that easy to find, and expensive when they are.
My most recent acquisition (last year) was a set of Letter size drills off of eBay. I watch what I buy there, it may be good, it likely is junque. Many sellers have no idea of the difference in manufactures of any cutting tool. [That guy was getting 50 bux for PTD, I should get as much for Chinesium] The Letter set pictured had USAF property stickers on it. I don't know the actual brand, but GSA tools are usually pretty good.
Then there are the smaller drills that came from the "expendables" stashes on ships (68-74) and the Pipe Shop (76-81). Again, I can't say brands, but they stay sharp when I need them. For a startup, I would advise sorta like the guys above, get a set of cheap (HF, TiN coated) and replace with good drills rather than sharpening cheap ones. Drills get used in all sorts of work, metal, wood, plastics, you name it. I use a number of 1/16 drills, so buy them in packs of 5 from HF. Some cheap sets work for years for non-machine shop work. Like fixing a hinge on the front door. Use what you can get and replace any that break or dull or bent with name brand stuff.
