- Aug 22, 2012
- 4,124
I thought I would jot down some reasonings of why I purchased the lathe I did.
I had zero experience prior to the purchase of using a lathe except for the 1st year of high school ie. 50 years ago.
I had some idea of what I wanted to use it for BUT did find that once I had the lathe many many more projects reared their head that I had never even considered so dont sell yourself short here.
Size, this was the largest lathe in the price range I could afford so price was the major consideration. Would I like larger? you betcha. could I afford it? not a chance so no real decision.
Tooling, I firmly believe high speed steel is best here, I received carbide inserts with the lathe and broke most of them pretty quickly. Sharpening HSS is easy and for hobby use close enough works, as experience climbs then the profiles become better.
Buy the tools you NEED as you need them, its usually cheaper. I have some tools I thought I should have and in reality they very rarely get used.
I purchased my cheap chinese 9x20 lathe with the full understanding it would require a full strip, adjust, re-build and probably a few alterations.
This turned out to be the case.
Have I regretted my purchase?
Nope because it has been a gigantic learning experience and skill building exercise and has enabled my to make many cool projects.
