- Apr 30, 2015
- 11,329
I can vouch for the reliability of the KB controllers, they use an older SCR technology rather than mosfet- hard to kill 'em
Mark
Mark
then what do you think happened--remember this was not the problem in the first place--it was a whining noise that I went to investigate--only then did the machine stop working--Thanks for any helpI can vouch for the reliability of the KB controllers, they use an older SCR technology rather than mosfet- hard to kill 'em
Mark
Because of Money--im retired with no incomeYeah, why just repair a tool when you can upgrade....
Next step CNC conversion
OK--But the lathe was running --and then I shut it off to investigate the noise--it was only after I switched the drive to reverse, then went to restart that the machine would not start--how can switching the drive direction cause a loss of power--they are two different functions--one mechanical--and one electrical-?You were pushing it too hard and smoked the controller would be my guess. Turn the chuck by hand and shift the lathe from hi to low, you should be able to feel if the gears are damaged.
is this controller the same as the MC-60 Tread mill controller-?--ThanksUsed KB controllers on ebay are far superior to the oem units. Just buy the appropriate resistor.
KB Electric KBLC-240DS (3375D) 87VDC DC Motor Speed Control Controller 115VAC | eBay
<p>KB Electric KBLC-240DS (3375D) 87VDC DC Motor Speed Control Controller 115VAC. </p><br><p>More information</p><br><p>-Input voltage: 115VAC / 230VAC</p><p>-Output Voltage: 0-87VDC</p><p>-Output Amperage: 6amps</p><br><p>Good working drive. Includes speed pot and 3/4HP resistor.</p>www.ebay.com
yes--not only did I do that but I took the back panel off and visually inspected the gears--not a nick on any gear in there--and they sound fine turning--it seams the sound is coming from the the lead screw--just found that out a few minutes ago--but still makes me wonder how it was working--when I turned it off--then only after I switched the drive direction--and went to restart the lathe--did it not work--thats what is baffling meYou were pushing it too hard and smoked the controller would be my guess. Turn the chuck by hand and shift the lathe from hi to low, you should be able to feel if the gears are damaged.
