- Sep 28, 2013
- 4,309
We are hearing you, it’s just a very hard problem to diagnose from a distance. We can only offer anecdotes based on our own experience.
For example, the front bearing on my heavy nine was a little loose as were the headstock bolts. There was no chatter but I was chasing down deflection issues (parting mostly). Now I have seen exactly that same issue, just yesterday in fact, with a couple of cutting tools that either had insufficient clearance or a small chip at the tip. Awful cyclic chatter marks just like that. Changed to a sharp hss tool and the problem went away. Certainly doesn’t mean doing the same would solve your issue, just saying that it solved mine
