- Dec 18, 2019
- 6,476
Finally, the confluence of time and material. Got sidetracked putting up a rabbit fence the other day. Felt like Elmer Fudd chasing them away all the time. Unfortunately I chose one of the hotter days to do this fence 97F. But it is done. Or at least until they learn to burrow under the fence. It was too darned hot to dig a trench by hand to bury part of the fence. I'll wait for a cooler day to do that. So my garden has a reprieve for a while.
Back to machining. Pins are cut off. Put them in the lathe to face them off and to slightly bevel the ends, so they will be easier to insert. Need to cut the notch in the pins for the retainer.
The 1.25" LOC 1/4" diameter carbide end mill came in the other day. Mounted it up and finished off the slot in the arms without any trouble. Pulled the arms out of the vise and inspected the pieces. Could see where the mill grabbed the bottom piece and dragged it. (Third photo, bottom arm is on the right.) Hope I can make that arm the bottom arm. If not, maybe the nut will hide the scar. Doesn't prevent it from being useful, so I'll keep it. Still have some more deburring to do on these pieces.
Next operation on the arms are to make a 5 degree cut in it. I'm still waiting for some angle blocks to do this.
While I wait, I will take a look at the body plates. They never were squared to my satisfaction (before mill) so now is the time to tackle this. (After notching the pins.)
