- Dec 18, 2019
- 6,480
Free hand is how I snapped the tap previously. It was in aluminum, which I hear gives more grief than steel.6-32 taps are hard to do without snapping the taps. At least I sure have trouble. And I think that a big part of the problem I have is when I try to run taps that small by doing it free-hand.
I made myself a tapping fixture which has a spindle /chuck . This helps a lot. The fixture is basically a copy of George Thomas’s pillar tool. I didn’t buy castings. I used big chunks of aluminum bar stock.
For these holes, I used the mill and a spring loaded point (tap guide?) in the chuck. The point just goes inside the top of my Starrett 93A tap wrench. Since I locked the mill in place to drill the hole, I just raised the head put in the tap guide and the tap is automatically centered in the hole. Putting a slight downward load on the tap helps as well. That being said, these 6-32 taps have a little windup to them. You can sort of feel the torsion build up in them as you are turning them.
