- May 3, 2017
- 1,997
I have a five-station manifold that comes out of the main water line from my well. Each station provides water supply to sections on the farm: house, barn, garden, pasture/shop, irrigation. This was done so that in frigid weather, we could turn off sections that were not in use, and subject to breakage because of freezing. Each line is 1" PVC with a PVC ball valve, and the entire setup is inside the heated wellhouse, so there is no danger of the manifold freezing.
Lately, however, I'm noticing the ball valves are beginning to 'stick' when rotating to On and Off positions. (I ALWAYS use both hands to prevent snapping off the plastic handles.) Is there a good product for lubricating the ball valves? I've heard of using WD40 but have also read some precautions against it. Any suggestions?
Regards,
Terry
Regards,
Terry
