- Jan 20, 2018
- 5,671
Looks to me that there is a well-defined ridge at the top of the way (picture 10), showing quite a bit of wear. Those can't be hardened ways, or that lathe has seen a LOT of use and not much oil. If there is flaking visible in the unworn areas of the ways, (far tailstock end), then they are not hardened. Hardened ways were ground. I have a '63 Heavy 10 with hardened ways that spent most of it's life in a somewhat crude job shop. The ways show no wear. Having said that, I've run worse. It's still quite possible to do accurate work, but doing it over much length gets to be a challenge since the wear is concentrated at the headstock end.
The price is not out of reason, especially considering the tooling.
