I like the idea but the more I think about it the best and easiest solution just might be to remove the rubber pad on the pedal and sidestep it.I thought a little more about this, and figured out a hydraulic circuit that would work. Split the hydro line into two parallel circuits, one with a needle valve for damped engagement and the other with a brake check valve to facilitate fast disengagement when you stomp on the pedal. Then put the line lock in series with the rest. So it would be a controlled launch but still release like normal. You could plumb the needle valve to your dash for fine adjustment. Only issue with hydraulic clutches is they are temperature sensitive.
We know, that sidestepping IS slower , and less consistent than conventional release, but anyway, took the local starter rebuilder all of 2 minutes to find one substantially smaller in dimension , so fabbing up a bracket shortly. The clutch is a 3 finger style with adjustment at the pressure plate, the car hooks good.I like the idea but the more I think about it the best and easiest solution just might be to remove the rubber pad on the pedal and sidestep it.
Been checking to see how your making out. The prototype picture did not show. ThanksHere's the prototype
Yeah, having troubleBeen checking to see how your making out. The prototype picture did not show. Thanks
