- Jul 26, 2011
- 4,142
Bridge City made a combination square with hardened steel dowels in the slot,to keep wear down to a minimum. With daily use,any sliding square will get worn. I expect the Starretts with hardened heads would be the most durable. I only rely on my fixed beam squares for serious work. I have granite squares to check them against,as well as a cylindrical square. Have a granite straight edge,and 3 camel back ones too,and a 4' Tumico.I'm a tool pig.
If you can find USA granite squares,they are the ultimate in accuracy. I did buy a Chinese granite square for the shop at work,though,and it was quite accurate(always a gamble though).
