- Jan 28, 2011
- 3,485
Contact SM is the right way to go.
Not your lathe but fairly correct for most machines, look up Grizzly G9249 owners manual. On page 59 is the beginning of how to setup the spindle bearings. The bearings will be loose when the lathe is cold, as the temp moves up the bearings, headstock and spindle change dimensions. You likely have to be warmed up to do the same for your machine.
Pierre
Pierre
