- Sep 14, 2014
- 438
If this was covered, my apologies. Also an old Soldier.
Have a shop do two punch outs for you in plate material of choice. 1st is the square hole. Then that gets punched out as a washer shape that will fit inside the tubing. Maybe start with a washer.
Drill the tubing, put the washer in the tubing, put a cross piece through and hold with a square on either side, Horror Freight magnet should be sufficient, tac with a mig, remove the squares, mig in place and grind flush.
