I have the setup shown below ready to drill tomorrow, figured I'd ask a question before I make a mess of things.
First, this is not a precision 1/2" diameter hole; it's a pass-thru hole, but I'd like it to be nice of course. Hole depth will be 2".
I purchased the drill from McMaster-Carr; it's a split-point which, according to the description, may not require a pilot hole. I have no problem drilling a pilot hole but I don't want to do that if it creates problems for the spilt-point drill.
So, should I drill a pilot hole? If so, what would be the best diameter for the pilot drill?
The small center hole in the part was made on the lathe just to double-check center on the drill press using an edge finder on the ER40 square block; the two methods agree nicely .
Thank you.
Thank you.
