Same here but just to clarify spiral point & spiral flute taps are not the same.
Spiral point taps as the name implies have only a spiral point & straight flutes. They are generally used for through holes & the sprial point pushes the chip ahead of the tap so they don't clog up the flutes. I believe they can still be used fine for a blind hole where the hole is deeper than the required threaded area so there's enough room for the chips. But chips will still need to be cleared out.
Spiral flute taps, the entire tap, flutes & all are spiral. These are best for blind holes where the chips will evacuate out the rear of the tap & out of the hole like a drill bit. Because the entire flute is spiral they're a bit weaker & can be broken more easily.
Lately I've had to tap hundreds of 6-32 holes using a sprial flute tap with a Tapmatic on some things I'm making. The spiral flute taps are awesome & work as designed leaving a chip free blind hole.
EDIT: Crap, misread your post, after posting all that blah blah blah I just realized you were talking about the two different kinds & not as the same. :banghead:
