- May 3, 2020
- 229
My mill (G0755) spindle sometimes rattles. If I touch the spindle nose when this condition occurs, I can feel a slow lane amplitude vibration. Maybe less than 10 Hz. It usually shows up to when I'm using an endmill larger that 1/4" or drills larger that 3/8". When drilling, the rattle does not show up under all drilling conditions. If the feed is aggressive enough and the grind is fresh, no problem. Milling side ways always produces the rattle
I put an indicator on the spindle nose, when stationary, mag base on the spindle gearbox. If I push hard on the drill chuck (6" lever) I get 2.5 thou deflection but it only comes back to 1 thou. Same if I push. So some of the deflection is elastic and there's is a dead zone? An I right to interpret this as slop in the bearings?
The bearings are 30206-P5 and 30207-P5 tapered roller bearings
If I run at top speed 2000 RPM for 20 min, the spindle nose warms up to about 100 oF. It's very warm but you can hold your hand there. I've had the mill for about 2 years but i didn't notice at first. I do a lot with 1/4 endmill and smaller drills, which does not exasperat the problem. It may have gotten worse but I was so green back then that i don't trust my memory
I am not excited about tearing into this. It's it normal? More preload? New bearings? Any input is welcome.
