- Jul 2, 2014
- 7,594
Surface grinders do not have purely radial loading, mostly perhaps, but not all. Ever heard of side wheeling? In addition, when you use radial bearings with side loading, even if only for the end thrust to axially locate and support the spindle and grinding wheel and resist deflection of the grinding wheel, the bearings will not be in their best loading orientation against the races and will fail early. Radial bearings should not be end loaded, and the grinder spindle preload does exactly that.
