Spindle acting like there is a brake
Happy to hear you found the problem.
Good job. Thankfully you sorted it and it was an easy fix with no harm/no foul.
Way to go!
to adjust the gears just run a piece of normal writing paper through the loose gears and than tighten the nuts that hold the gears.
In so doing you will have jut enough clearance between the gears .
