  • Guest,  We want to wish You and Your Family a Healthy, Happy Thanksgiving! Click the "X" at the top right corner to remove this notice)
4
Spa Motor
3
Like what you see?
10
Blackhawk
Active Member
Oct 20, 2012
254
Likes
12
#1
ive got 4 4hp 220 spa motors, probably same as a pool pump motor. Would it possible to use on my lathe and mill? Or am I talking crazy? Hate to waste a good motor
Thanks
Lanham
CluelessNewB
Active Resistor
H-M Supporter-Premium Member
Mar 3, 2013
982
Likes
424
#2
No it's not crazy. Many spa/pool motors are 2 speed (slow speed is usually much less power). It may have a weird shaft. Many are NOT reversible. My Dad had an old pool pump motor on a drill press for years. It is 0.75 hp on high (1725rpm) and 0.21 hp on low(1140rpm) . It worked fine, I still have it and I'm planning to use it on my Atlas mill. If it were me I would give it a try!
WalterC
Active Member
Active Member
Jul 3, 2015
69
Likes
48
#3
You might check and see if it is a capacitor start motor. On a lathe, there can be a lot of torque required to get it started.
silence dogood
Jul 10, 2013
329
Likes
178
#5
For a number of years, I worked on spas. It seems to me that spa motors should work on a lathe. Most that I know of are capacitor start. Many are two speed, low speed for circulation and high for jets. If single speed then it was high speed in order to run the jets. A small motor would run the circulation. Now a couple things to watch for, there were a lot of cheap spas that used really low grade motors( we had to replace one where the shaft actually broke). The other thing is check the bearings. If you see what looks like a white powder coating the motor especially where the pump was fastened, it is calcium. That calcium comes from the owners neglect. The calcium is like sand and gets in the bearings and ruins them. I made lots of money from replacing motors or getting them repaired, because the owners would not do some simple maintenance. Good luck and let us know how it works out. Mark
CluelessNewB
Active Resistor
Mar 3, 2013
982
Likes
424
#7
The 3450 rpm high speed is a bit problematic but even on low speed 1725 rpm it's about 3/4 hp, enough for a smaller 10-12" lathe. It doesn't appear to be reversible.
Ulma Doctor
Infinitely Curious
Active Member
Feb 2, 2013
4,298
Likes
3,495
#9
nope not crazy at all,
3450 rpm is usually a bit fast to run a machine tool,
but in a milling machine the extra speed could come as a boon for small endmills that need to run at high speeds
f350ca
Active Member
Jul 11, 2013
1,181
Likes
1,843
#10
It probably has a tapered shaft to mount the impeller. I built the end up with weld and turned it down, then cut a keyway to use it on a pressure pump. Works well but seams low on startup torque, won't start the pump against the unloader valve, have to hold the handle open on the first start, then its fine.
Greg
6
5 7
