South Bend 9b Spindle And Change Gears
That's a 32 tooth in the pics
Out of aluminum. The arbor holding the gear blank is long enough for 2 blanks at a time , so I'll make 2 sets at once . The arbor on the mill I made to fit a 1" end mill holder I had and the cutters are a 16 mm keyed bore. I didn't put a key slot in the arbor just holding it with the bolt in tension seems fine in the aluminum but probably will add a key if I go for steel gears.
