If you cut many threads a gearbox is very worthwhile.
Trouble with a wiper motor is that they need so much amperage to run. Mine needed a 12v car battery or cordless drill battery to run properly.
Adding a handwheel to the end of your leadscrew on the tailstock end will enable you to vary the fine feed with finishes very close to power feeding. You may need to mill off some of the leadscrew bearing support to fit the handwheel.
Have you actually used this lathe yet?
Hi
Many thanks for the video link. This is so good!
I used the lathe only for the short while it took to verify that all was running smoothly. I did all the obvious things one does when trying out some new acquisition. It was all I needed to then decide on some changes. The previous user had reversed the pulleys on the drive counter-shaft, and made an arrangement to mount it from a block on the floor. Also, the bench was way too low for me. I plan to put it back to original, and on a better bench height.
I picked up the lathe with two extra 4-jaw checks in good condition, and a whole bunch of extra tooling for the quick-change post (Sandvik carbides) for the equivalent of $147.71 (at the time), after an unexpected eBay bid withdrawal mayhem.
I began a clean-up, and resolved to put the (very green) paint job back to something like the lathe in the video link, while checking out and fixing anything that needed it. I will probably do things in careful stages.
The current state is non functioning, simply because I have the motor assembly taken off for refurbish and a new drive belt. All else is still together, after a wipe-down, and covered in light chainsaw oil.
Regarding my reference to "electronic gearbox", you are right about amperage if one is using 12V DC wiper motors.
The current is of course much lower for the same torque if a higher voltage AC servo motor is used. Servo drives I have used in my work always make a rectified DC bus from the available AC mains supply, and then use higher frequency switching electronics to deliver synthetic AC to multi-pole AC motors. With encoder feedback, these can deliver high torque, smoothly, even at very low speeds. With another encoder on the spindle, it is possible to electronically contrive any desired ratio relationship within the capabilities of the servo. The price of these has been coming down for years.
For the lathe, I would still go for having the lead screw turned by gearing, whether that be change gears, or a nice convenient gearbox. The old South Bend need not aspire to be servo-controlled. In good condition, it is capable of excellent work and a joy to own. A servo leadscrew is a real good solution if a gearbox is too expensive or hard to come by, and probably the sort of project that makes one feel pretty good when it gets to work.
