- Nov 12, 2014
- 151
I'm assembling a 10k I bought some time ago that was partially apart. Currently working on the saddle and cross slide. From the unclear drawings I have been able to locate there is a pin and set screw to adjust the cross feed nut. There is a pin in the side of the nut that I cannot get out and was thinking of drilling it out. Does it go all the way into the screw from the top? It seems it does because I cannot remove the top screw. I thought this screw was only for oiling the cross feed screw. This nut seems tight on the CF screw and hoping to salvage it and reuse. I can make a new pin from CR steel but need to know the length and end tapers.
