- Dec 24, 2020
- 1,058
I honestly wouldn't worry about the bearings...lots of Sheldons are still running on original plain bearings. I've had two 13" Sheldons and they're good machines. I still have one, and have owned a Heavy 10L...I sold the SB if that says anything but it was a nice machine.Looking at pictures I think it’s new enough to have roller bearings in the headstock. Do you think that’s accurate? If they are sleeve bearings Whats the chances they are worn out?
The one on FB is easily worth the asking price. It's got the steady and follow rests, micrometer carriage stop, threading dial, collet adapter/collets, etc and those would add up to $1,000 if you sold them. If the extra apron has a good casting that's worth several hundred as well and more if it's mostly intact and could be rebuilt. Being local might be a sign!
Edit: One nice thing about the Sheldon design is that the webbing for the bed is usually in the right place to be a perfect spot for lifting. Use a sling choker style around a web near the headstock and then adjust the tailstock and carriage position until it's level and you're set. That's also a safe way to lift since the lathe can't spin like it can if you run a strap around the entire bed. Even a HF cherry picker should be able to lift it.
If you have to do something to move it towards the garage door, be very leery of things like furniture dollies. If you go that route you need to strap the machine to the dolly so it can't slide off if you hit a pebble or crack in the concrete (ask me how I know this can go bad quickly). Sweep the floor clean, then try to move as straight and slow as possible. Sideways pushes are what sends them over so that's the critical time as you move them.
