- Nov 27, 2012
- 7,863
Wonder if "Drill Spot" is Travelers?
Drill Spot is not Travers. Drill Spot is just a "broker". AFAIK they don't actually stock anything, whatever you purchase from them will be drop shipped from the supplier, Travers is one of their suppliers. Generally their prices are higher than going direct but there were a couple of times where I found Drill Spot's pricing to be cheaper so I purchased from them.
Will, thanks for the ebay seller. I searched his store for the GTS-1M.
The link you provided looks very good. Perhaps I will call Dorian tomorrow to confirm my tool requires metric. Probably not much chance of getting any help from them though based on my prior experiences. The haven't yet learned how to spell customer service.
For something like this, I personally wouldn't even bother calling Dorian. Easy enough to figure out on your own.
Most of my indexable tools are Dorian & pretty much all of the indexable tools I use (as well as those that are not Dorian) that use screw down inserts use metric screws. In this case it's not about where the tools are made that determines the type of thread, I believe it has to do with ISO standards for inserts & is why screw down inserts are usually metric.
That's the reason why I mentioned to research first before buying from that vendor. The link I posted was just a quick search, it may not actually be the correct ones, I don't know. Tool manufacturers use their own odd P/Ns for screws. I would just measure the screw & see if that ebay seller has something suitable for replacement. Or message the ebay seller, I'm sure he can help you get the correct screws.
