- Feb 1, 2015
- 9,622
I have successfully soldered stainless steel and aluminum with rosin core solder. Clean metal and good solder are key to success.
I use acid for electrical, heavy stuff. For my F3B winches, I crimped the welding cables with terminal ends (forget what they are called), then used the acid core, and soldered the connection.
You're lucky.I can';t recall ever having a crimped, then soldered fail.
If soldering is done properly and the wire is clean, the solder will also wick back into the insulation, giving additional support to the wire and preventing stress breakage.
