- Feb 1, 2015
- 9,605
To control inrush current, I have used a varistor. A varistor is a resistor with a negative temperature coefficient. They are most commonly used to limit inrush current to switching power supplies. At start, when the varistor is at room temperature, its resistance is high, limiting current. It quickly heats up which drops the resistance to a fraction of a percent of the cold value.
In my case, I bought one that has a 10 ohm cold resistance and a 15 amp capacity. On a 240 volt line, the initial current draw would be less than 24 amps and probably disregarding the resistance of the load. As the varsitor heats up, its resistance will drop to around .05 ohms which mean a .75 volt drop.
I purchased mine from Digi Key for $2.40. https://www.ametherm.com/datasheetspdf/SL3210015.pdf A m,multitude of varistors with different specs are available. I would use a clip on ammeter to determine your steady state current draw and order accordingly.
There is a drawback in that the varistor needs some time after shutdown to cool down before restarting to obtain maximum inrush limiting. If you can allow several minu6tes between shutdown and startup, it shouldn't be a problem. Starting up after a shorter cool down period isn't a disaster. It just means the inrush current will be higher. Worst case, it won't exceed what the original inrush was.
