Sofia Lathe
Woodemp
Oct 1, 2015
11
Hi. Any one have info on a Sofia Universal Lathe. A friend has one and we have a problem reading the thread and feed charts. Anyone who can help would be greatly appreciated. Its a Model CU40D.
Tks
I have only a passing familiarity with Sofia lathes, in that a company I used to work for had one. Can you post a photo of the headstock panel? I believe they have offered several different layouts/configurations, so a photo of the machine in question should help. I seem to recall the one I ran a few times was terribly confusing until I finally figured out which lever did what in relationship to which chart, and none of that was obvious or intuitive!
We can setup for the black sections but couldn't get the red sections. Tried to set up for 6TPI but no success. Also couldn't figure out what the numbers at top meant. 20 - 2000 etc
Those charts are ringing a bell, but it's a distant one. Can you get a high resolution photo of the control panel that shows the levers? I'm thinking ours had levers, but that lathe may have been one with dials.
Can't get Pics at this time. The speed gearbox has levers but the feed box has knobs. center one has numbers 1 - 8 and the other one has numbers 1/2, 2/1. etc
These lathes where also sold under the Ajax brand in Europe. You could try finding a manual for one under the Ajax name.
