- Feb 2, 2013
- 3,628
to my knowledge, a rule(r) measures,
a scale is the representation of the measurement.
I prefer for measurements to be called out in inch. I refuse to let it slide if I'm working with someone that calls out such a number as 10' 3" & 3/32 of a inch when I'm cutting a brace. I use feet when a few inches doesn't matter. everything else is measured in inch usually down to an 1/8". It wasn't until I took up the hobby of machining I started using tenths, hundredths, thousandths , & ten thousandths.Well as I am just trying to get CAD figured out I still use A drafting scale. That said by the first definition given here A scale may not be a ruler, But a ruler could surely be used as a scale as in 1/2 " = 1" I like to nag apprentices that call out dimensions like 35". I have to explain to them after 12" you use feet and inches unless you are going to sew the steel in place. But I just do that to hack on them and get them used to using feet an inches, because 356" just sound so wrong.
Mark
Old-timers may recall drafting pencil lead hardness classifications: for example, 5H was often used for
