How do you access 'All of Craig's list'?'All of Craig's list', searches everywhere. Dozens of other Craigslist seach engines exist. Try a few and find one you like.
Regards,
Terry
Here is what I use.How do you access 'All of Craig's list'?
Regards,
Terry
Aaron what did you buy?Another consideration for combo machines, you may out grow one function before the other.
I have a mini-lathe and a mini-mill, I just bought a bigger lathe because I was bumping up against the size constraints of the lathe. So far I am still well within the capacity of the mini mill.
It looks to me like most of the 3 in 1 machines are based around a fairly good size lathe combined with a rather small mill. Not sure which machine you are specifically looking at but the Smithy Granite is based on a 13x24 or 13x40 lathe, which is a respectably large lathe for a home shop, but the attached mill (Spindle to table 13.38", XYZ 9.5" x 7.63" x 10.25") is not much larger than my Sherline mini-mill (Spindle to table 12", XYZ 8.65"x 5.0"x 10..25"). The Smithy mill does have a more powerful motor and larger table.
ThanksHere is what I use.
I started with a Sherline 4400 mini-lathe and a 5400 mini-mill. I recently bought a used Logan Powermatic 10x24 lathe.
I'm not doing gunsmithing. I started off with the Sherlines for doing model work and have expanded into wanting to occasionally do something larger. I don't have a big shop so a 10 or 11" lathe was about the largest I could comfortably get in there.
I just point out the size difference between the lathe part and the mill part on these 3 in 1s because most mini-mills are bigger than the comparable mini-lathes, not smaller.
Is space an issue for you? You haven't mentioned if you were looking at the Smithy for space issues, cost, or the convenience of one stop shopping.
Just for a price comparison for the same $5500 or less you could buy a slightly smaller 12x36 lathe ($3000-4000) and a larger bench mill ($1500-2000) from Grizzly or Precision Matthews.
A 13x40 lathe is going to run about $5000 alone, but it will probably be a better lathe. A small bench top mill about the size of that included with the Smithy can be had for $800-1200 and if you find it too small you can sell it and upgrade, or just spend a little more upfront and get a better mill.
That's a great principle to employ! As you gain experience, you will eventually become aware of the tolerance levels of your equipment and recognize a larger/heftier machine can do more. That's a no-brainer. But IF you do your homework and buy right the first time, that's nothing more than an observation. If you under-buy, you'll find yourself selling and upgrading. That'll be frustrating and cost you money in the long run.I’m a firm believer in do once and do it right, and I just can’t make up my mind
