- May 4, 2019
- 792
Would something like this work? https://flexpivots.com/flexural-pivot-products/
That would be good, except most have a bevel or even a step along its length. If one is available that is actually just flat and parallel, then yes, that would be a good solution.I think that a hss lathe parting tool would fit the bill. And, it can easily be cut with a rotary cutoff tool.
Interesting! However, those are not frictionless as is claimed. Bend them back and forth fast and they will get warm from the friction amongst molecules and grains of the metal.Would something like this work? https://flexpivots.com/flexural-pivot-products/
Yes, that's a very good idea. Probably not as hard as the knives and other options, but they are cheap enough to be sacrificial to some degree. And there are one-hole models that could offer convenient mounting. I was thinking of rigging a test stand for trials, and that could make things easier.1-2-3 blocks without the holes are hard, flat and cheap.
That looks very promising! Thanks!I've used RNG shapes, in tungsten carbide, for this kind of thing. They come already ground flat both sides, kinda
thick coin shape, and can be shrink-mounted in a steel socket, to keep the edges from being a bother.
RNG at Kennametal
