- Nov 14, 2016
- 3,010
I think this is the crank from watching the video.
Lathe arrives later this week so I will know then.
That is the lead screw crank.
The current threading attachment is turned by its own crank, and the motor needs to be disconnected when in use.
While there are likely some differences, Sherline has kept the current model largely compatible with the older ones, the motor being one of the major changes. If you need instructions they have them online for download. While yours might not be 100% compatible with every product I've found Sherline's customer service to be very good, and they can probably help you out in regards to what fits and what doesn't.
Sherline accessory instructions
