- Dec 18, 2019
- 6,527
The Sierra American 1" arbor uses a 5/16"-18 thread. Just turn down the head of the screw. Takes a minute of your time and it is done. Also chamfer the back side of the screw head to remove any burrs from the turning. Then you can get on with life.
This assumes that the only thing wrong is the screw hole is off center.
If you bought this arbor from McMaster, please send them a note that your arbor is made incorrectly. They will offer to send you another one. It will also probably off center. Mine was. You can also send a note to Sierra American. If you don't tell them something is wrong -- they will never know. Sierra American has a quality problem which they don't seem to be acknowledging. Perhaps more reports will get them to realize there is a problem, at least with the lot that they shipped to McMaster. The issue is they are drilling the hole in the wrong place, which tells me their drilling fixture has an offset problem... Or their counterbores are way too tight!
