- Jul 29, 2014
- 2,743
Today I finished and tried out a platform to hold my router and keep it a constant height above a rough slab, so I could get a plane surface. Awhile ago I saw on eBay some precision rails and recirculating ball guides for a surprisingly low price, around $100 for 4 1000mm rails and 8 ball guides. I finally got around to making some supporting parts that give it a range of about zero to 12” high. I used a 1.5” straight flute carbide cutter. I was concerned that there would be too much vertical play, but it was really rock solid, with a surface finish that looked just like it had run through a planer. It slides in XY very easily, is quite controllable but reminds you about conventional vs. climb milling. Similarly the horizontal stability was fine, even just supported on a sheet of 1/2” plywood on sawhorses.
i have some nice redwood, walnut and oak slabs that I’m anxious to run through this. Only downside is it sure makes some chips!
