- Apr 4, 2016
- 853
I'm guessing that the motor in your lathe isn't dual voltage (220/440) so that you could just re-configure the wiring at the motor ? If the motor is a single voltage, 440V motor, have you considered the possibility of changing out the motor to a 220V, 3 phase, 60hZ motor. It may not be any more expensive than the transformer you're trying to find. Of course, you would also have to make sure that the control voltage requirement for your machine isn't also 440V if there are components such as relays, magnetic starters, transformers, etc. Just some food for thought.
Ted
Ted
