Single point threading questions
This is a screenshot from a mrpete222 video showing “the right 30°“.
I had my lathe set at the wrong 30° for awhile, and it didn’t work out so well.
I will leave it to others to recommend 29°, 29 1/2° or 30°. Personally, I do 29 1/2 or 30°.
Thank you guys so much!! I read each post and jotted everything down. Right after dinner today I chucked up some steel and turned it down to dimension. I adjusted the compound slide to 60.5 degrees and mounted a dial indicator.
After the initial scratch pass I disabled the motor and turned the thread by hand. I continued to turn the chuck and dial in the compound a little at a time until it started looking like a thread. Aside from my forearms aching I feel good about the end result. Not as finished as maybe it should be, but the nut fits and moves smoothly.
I feel confident the next project I need to make threads I will be a able to. Thank you!!!
^^^Whatsit?^^
I'm going to guess for turning the lathe by hand?
Finish your threads by running a triangle file in the throats of the threads (under power). Then, use a mill smooth file to smooth the tops of the threads. These operations will remove the many burrs that threading can produce.
It goes through the back of the spindle. A twist of the wing nut expands the arbor.
What a great idea. Do you leave that mandrel in the spindle all the time, or do you just put it in when you are threading to a shoulder?
