Simple Questions
speedre9
Aug 26, 2013
167
I have a 12VDC, 30A power supply, it has three lugs each marked v+ and v-, does that mean I can power three things within its rated specifications? Right now as it stands I have only one item attached to one power supply. Comments?
As long as the combined load is within the power supply's rating, you're good to go. The 3 terminals are just there for wiring convenience, in case you want to add something.
Thanks Jim, that's what I thought. I refuse to just assume without asking first. Thanks again.
