- Dec 2, 2016
- 238
I have an old German cylindrical grinder I have been working on and I am trying to understand the 6 lead motor wiring on a 2 speed motor.
The switch disintegrated and left me with a motor that buzzes when the switch is turned on it eventually trips the breaker.
The motor wiring starting with the 6 leads goes UaVaWa above, below that is UbVbWb. The plastic identification clips used on the wires are on top U8V8W8 and below that are U4V4W4.
So measuring the resistance on the U winding its about 70 ohm, on the V winding about 70 ohms and on the W winding about 140 Ohm's
The voltages follow the same pattern about 220V on U and V and about 440 on W. When I flip the rotary switch I get the buzzing but was able to see on my multimeter about 2 A's being drawn on the U winding, before it tripped.
Below are some pictures of the switch. My question is how many poles is this switch 3? What would I be looking at for a replacement considering the motor wiring? There seem to be plenty of modular rotary switch on line that can handle the voltage reuqirements but not sure on what I would need considering the configuration of the siemens over engineered broken one.
I
I
