- Apr 30, 2015
- 11,329
OK, what I believe you have there is an SCR controller similar to the KB electronics designs. Probably several solid state components are damaged. The chip in question is most likely a LM324 quad op amp, but something else failing on the board blew it up. You would need to check all the power devices and the power rectifiers D16 thru D19. You might be better off trying to find a replacement controller (like the aforementioned KB brand) You can often find them on Ebay for less than 100$ US
-M
-M
