Hello, I recently purchased a Sidney lathe & need manuals for it. I found manuals on ebay but they appear to be for an older lathe. Any help would be appreciated.
Charlie, Seems like you and I are part of a small group that have Sidney lathes. Yours is newer than mine so I don't know how much help I can give you. Mine is pre 1930 and set up a little different from yours. I'm on line here every day so you can always send me a PM and I'll try to help. I don't have a manual but know my way around mine.
******Just Saying**********Gator***********
I was able to get the old girl moved into position & working on changing over from 440 to 220 now. Does anyone have experience with a static phase converter on a 7 1/2 hp lathe motor? I can run a rotary phase converter but would rather go with the static if it will work ok.
