Re: Shop made tooling
This first one is a rigid tool post I built for the lathe at work. I got tired of the rocker style tool post. Every time you tried to take a heavy cut the tool
would be sucked in. ( I found out later that the post was cracked in 3 places). Also the holders that we had were angled to much for the indexable carbide
I wanted to use.
The tool sits on a piece of key stock and is adjustable for height by a set of jack screws in the bottom. This way I could set it to the centerline of the lathe. As well as change the rake of the tool
if I wanted. The t-nut in the compound is milled to be flush with the face of the rest, this allows me to get right up to the jaws without hitting the compound. And just for fun, I use a nut that was the same size as the tailstock wrench on top. the slot on the othe side hold a cutter with a smal radius for finish cutting I put it in oppisite of the other one and switch between them by rotating the whole tool post. With this setup I have no trouble taking .300 off the overall dia In a single pass.
Here Is the LeBlonde in action I am turning a 2" Hub off of a gear with aprox. a 12"dia. In this pic you can see the second cutter installed in the tool post. Its not a quick change, but it gets the job done.
This is a tap drill/tap guide block. It will do 6-32 through 1/2 -13 all in a 2"dia by 1" thick piece of round stock. A handy little tool to be sure.
This is a fly cutter I made. It is at a 30 degree angle and is 2.500 dia. Does a nice job.
I got bored the other night at work and decided to make a "Man's Hammer" This little bugger is only 14" top to bottom but weighs 12 lbs. I call it my "fine Adjustment tool"
Ben
