- Nov 8, 2011
- 1,678
I have the Slater internal and external rotary broaches
Care to share how you did this one?
I thought the commercial rotary broach holders were priced way too high for what they are so I rolled my own. Body and tool holder from scrap 1018 crs, modified MT3/JT4 drill chuck arbor $8, ball and thrust bearings $30. I still need to make a straight arbor for using in the mill. Cutter in picture is 1/2" hex from Polygon. I plan on making my own as soon as I get my furnace built. So far I have used it to hex broach steel pinion gears.
View attachment 66105View attachment 66106View attachment 66107
Jay
OK, so it's very similar to a rotary hammer drill in action. What I want to know is how is he producing the wobble?
I know that now. I was so fascinated by it that I'm actually building one now. You can read about it here: http://www.hobby-machinist.com/showthread.php/19945-Shop-made-Rotary-broach-holder-and-broachesIt produces a wobble because the longitudinal axis of the cutting tool is off by a degree or so compared to the axis of rotation of the work being cut.
When the work rotates ( or vice versa with the cutting tool) the cutting tool is carried with it but since the tool center line is not square with the work a rocking motion is produced whereby the cutting edges of the tool move in and out in a reciprocating motion against the work.
It's just like the tool edges are chiseling the work in a rapid succession.
I hope I have explained it simple enough.
I've had a little brass hammer for many years that someone made long ago. It is definitely used and I always think about who made it and what they were thinking when they made it. It's a good feeling to know that something you make will last for generations, so with that being said, I decided to make my own version of an aluminum / brass inserted hammer that hopefully someone 40 years from now will appreciate. Very basic, but I enjoyed it very much.
I completed my drawbar wrench/hammer for my X2 mill today. I’m quite pleased with it. It’s not perfect, but I’m proud of it. It was made from a store bought deep socket, and brass and aluminum I inherited in Dad’s workbench. This project was based on and inspired by the Soft Faced Hammer Project on the Projects in Metal Forum.
Chuck
