Should I put leveling feet on my lathe?
Or cut the legs down on your current table some 3'' and pour a 3'' cement top (like kitchen counter tops), armoured en all.
Bolt the lathe solid to it. That would help control vibration and prevent twist.
I'm thinking of cutting the current table to the middle leg so the mill can still use it
That could work. Here's a suggestion. (Maybe not a good one without physically seeing the table.) You might want to try that first. Then, if it fails, you're not yet committed on the new table and re-think it if necessary.
Regards,
Terry
I've been turning stainless steel today and in about 4 inches, there's around .0008 taper from end to end. Is this good or bad? The lathe is still on the same table. Both table and lathe are unleveled.
I was gonna suggest pouring a 2" thick Concrete top. If you plan ahead you can place some anchors into the wet concrete to make things easier down the road and best of all you can keep the current bench exactly as it sits!
Top Bottom
