Should I be concerned?
imagineer
Dec 7, 2022
87
Should I be concerned…
This past weekend I had some time to waste, so for kicks, I made a “speed handle” for the milling machine vise. The vise is Vevor brand and has a 14mm drive hex. I sacrificed an old 14mm deep impact socket to make the middle and end drive points. The boss for the handle was turned from ¾” round bar. The tube sections between the drive points and handle boss were cut from a long since retired floor jack’s handle.
The floor jack was of Chinese origin, so the OD of the jack handle was something metric, just under ¾”. The OD of the 14mm impact socket was about .870”. To fish cut the ends of the tube, I used 7/8” and ¾” end mills. Given the non-exact diameter of the jack handle tube, I was having trouble getting the cutter centered on the tube. The math was there, but the backlash on the Y axis lead screw and a slipping index wheel kept messing me up. After quite a bit of trial and error, I got it close enough to mill the tube ends. A little TIG welding, a shoulder bolt and a bit of PVC pipe, and the speed handle was done.
This morning on the drive to work, not sure why, but I started thinking about the frustration I had getting the cutter centered on the work . . . then I remembered . . . last month, I installed a 3-axis DRO on the mill . . . and it never occurred to me to turn it on.
That handle is going to suffer from identity crisis all its life...
All joking aside, good job using what you had available to make this. Pretty cool.
I wouldn't be concerned , but watch out for pinching your finger between that shoulder bolt head and pipe handle . I can see blood blisters in your future .
