- Feb 1, 2015
- 9,645
I believe you are referring to calcium chloride, and commonly used desiccant before silica gel.Silica Gel works very well to achieve a very, very low humidity environment. Unfortunately, anything but a well sealed container is pointless as silica gel has very, very low capacity.
Calcium Chlorite (Sold as Damp-Rid) has much greater capacity and can be used in semi-open environments like closets and draws. .
Calcium chlorite is strong oxidizer with potentially explosive properties when in contact with combustibles.
You are right. Thank you for the correction. That was 45 years ago and the old brain box isn't what it used to be.RJ,
Are you sure it wasn't 150 C. I've rejuvenated lots of Silica Gel in my lab days and I don't think 150F would do the job unless in a vacuum.
I dry silica gel at a higher temperature myself, more like 250 - 300ºF. (According to Wikipedia, 120ºC is the recommended rejuvenation temperature.)
