Generally, I regard setup tooling as permanent fixtures/ jigs that serve in a restricted sense, suitable for limited operations or parts. Does not apply in every case, but any can envision fabbing up something, that spends the rest of it's life collecting dirt on a shelf. If it works; name it, take a picture of mounted part, creating a reference for later.
Other times, a collection of simpler items does the trick, parallels in this case. Great supporting part in a vise, until opening to load another. Coolant knocks them over, chips get underneath them, or they fall while reloading.
Grrrrrrrr.
Now, before asking for pictures, a valuable trait of machinists is cultivating ability to visualize. . .besides this isn't MTV, I'm not Peter Gabriel or David Byrne.
I'll offer set of favorite hacks regarding parallels and machining vises. We've seen many; separators [spring loaded tubes outside the jaws], or coil springs bearing against them, or two drops of fast-set glue, or magnets, or rubber bands [!], or nothing at all....
I use strapping tape, the steel variety binding loads to pallets. I simply cut a length and form one of three ways, depending on part width.
#1 is hair-pin like, one leg longer than the other. Longer is convexed to contact ends of parallel, the shorter hits middle of opposite bent with a little snow ski like tip. That keeps it or parallel from moving out of jaws opening/ closing on repeat parts.
#2 is great when drilling; a simple U-form, with ski tipped ends.
#3 for wide items; roll a circular length around 3x the jaw opening and lap the joint with a strap clip or bend acute interlocking hooks.
#Freebie. I don't work production; but time saved means I work on my own projects. When possible, instead a lot of deburring, use 4 parallels. Outboard of those supporting workpiece, insert shorter parallels at the jaws. Instant chip and burr clearance.
Grrrrrrrr.
