- Mar 25, 2013
- 4,625
I tested the Rhino bar today:
It is dramatically quieter than the Thule bar. It is a smaller profile and a more aerodynamic shape.
I also made a mount as proof of concept:
I would like to put something between the mount and the roof rail. For the test, I just put some tape on the back of the mount. That would work, but is there a better material? I could get a thin sheet of plastic? Rubber? Any recommendations? Keep in mind water and UV.
I plan to use M8 pin in torx head screws. All the hardware will be SS except for the load bar. Inside the rail will be a threaded SS plate. Toyota made no allowance to get something inside the rail so it will have to slip in the slot that you see.
